Message 17 of 17
Posted by member Joanna Bryant on Thursday 9 September 2021
Thanks Clive yes I agree we do want a canopy like yours and Michaels I will give Dorset trimmers a call. Not sure if they are still in business.
I have had a quote from C & J marine only problem is we would have to fit the cover ourselves as they are in Chichester and rather pricey for them to come out to fit.
Have you or anyone had to add new lacing buttons to the hull and fit the two hoop canopy?
Message 16 of 17
Posted by member Clive ffitch on Wednesday 8 September 2021
Hi Joanna,
Hope I'm not too late with any comment! You have likely noticed there are two "styles" of canopy that boats seem to have - one much like yours, with a heavily sloping aft panel, and those with a "fuller bodied" shape which gives better standing headroom and space within - especially as many canopies stay up throughout the season (especially with this last season's weather!) and effectively extend the living space considerably. I would definitely recommend the latter style, much as with Michael's canopy, and the one on Adele that we have (see photo).
Additionally, I would recommend the canvas style material, rather than PVC style.
Ours just has the single stainess steel frame on sliders, but is fully tensionable. For added reference if you need it, ours was new when we bought Adele, and is still going strong. It came from Dorset Trimming 01305 771708 if they are still about.
Message 15 of 17
Posted by member Joanna Bryant on Monday 6 September 2021
Thank you
Message 14 of 17
Posted by member Michael Herridge on Tuesday 17 August 2021
CJ marine near Chichester make a very robust and taught cover using two s/s hoops. This one is over 15 years old and hadn't been cleaned for a long, long time. Gives full headroom etc. Sorry I haven't a better pic.
More recently I have had it cleaned (yes it is blue!) a couple of small holes patched and windows replaced, they were very brittle and cracked in cold weather. I reckon it has a few years life left in it yet.
Regarding repairing windows, I found that Gorilla tape to a clear tape, use it on both sides of the cut/crack and it appears to last well.
Message 13 of 17
Posted by member Joanna Bryant on Friday 13 August 2021
Thank you Nick I will talk to Nauticover about our cover. I have also seen Sheridan Marine have parts for the frame so we should be able to do something about that.
Message 12 of 17
Posted by member Nick Askham on Thursday 12 August 2021
Hi Joanna - the hoop for the canopy on my Pilot is held in any one place by large screws through the sliding fixture at the end of the hoop. Obviously for the hoop to remain in one place it has to be able to be fixed. I'm sure that a competant engineer would be able to fabricate something to do the job easily.
Regarding the replacement canopy at Nauticover, my understanding, having spoken with them on the telephone in the past, is that they have templates certainly for all the smaller Hardy boats including the Pilot. They would only use one's original canopy as a template in the absence of their own.
Regards, Nick.
Message 11 of 17
Posted by member Joanna Bryant on Thursday 12 August 2021
Thanks Tony
Message 10 of 17
Yes we have put new bungees on and have it as tight as possible. The frame is on sliders but doesn’t have any stays or wing nuts to keep it in one place. Nauticover will only make an exact copy using the current covers as the pattern.
Thanks for your advice.
Message 9 of 17
Posted by member Anthony Weald on Thursday 12 August 2021
Hi Joanna. I hope that Nick's advice tensions your canopy successfully.
We had a new cover made about 8 years back and it's still a good fit
Made by KLS Marine on Canvey. It wasn't cheap but as part of the deal they did the first fit and tensioning on the boat, at our club.
Not sure how far they would travel to do this.
All the best, Tony
Message 8 of 17
Hi Joanna - your canopy looks rather loose in places and I wonder whether you have the hoop fully upright. I'm not quite sure of the technical terms so please forgive me if I'm incorrect in my terminology.
The hoop can be moved along the runners; certainly on my Family Pilot I sometimes have it forward slightly to give a bit more slack in the canopy, whereas right back toward the stern tensions the canopy more. The other thing I would look at is the ball bungees as they certainly help tension the canopy; they seem to get tired over time, I guess that they just stretch.
Finally regarding a new canopy, it would be a pity to buy from the same seller and have the problem once again, albeit your canopy may have stretched over time. A number of Hardy owners have, I believe, puchased a canopy from Nauticover and have been satisfied. You can find them at: www.nauticover.co.uk and on their home page is a Hardy Pilot (I think) resplendent with new cover.
Hope this helps,
Regards, Nick.
Message 7 of 17
More help needed please -
We are having problems deciding on the new canopy - does anyone have any advice on fitting the canopy so it doesn’t hold water around the bottom edge.
If we order one from Suffolk trimmers it will probably be the same fit and therefore have the same problem. I have posted a photo to show the area that needs re designing - anyone else experienced the same issue?
Message 6 of 17
Posted by member Regent on Monday 2 August 2021
Dear Joanna,
I have all the original manuals/paperwork for my Pilot SE, including for the SMEV cooker.
Yours looks the same as mine and looks like the Serie 2000-2500 (see image of the cover of the brochure from my files).
Message 5 of 17
Posted by member Johnny Talbot on Tuesday 20 July 2021
. . . sorry reference the hob, I forgot to say that I'm sure its the same as mine which is a SMEV - exact model unknown. There are all sorts and sizes on the internet and they ( and their spares) appear to be widely available and are fitted in campervans etc etc. Johnny.
Message 4 of 17
Hello Joanna,
I've just had a new canopy for my Bosun made by Arun Canvas & Trimming - an excellent job. Cost was £1600 which may be a little expensive but you get what you pay for. Looking at the Social members list, if that is you at Christchurch, you're obviously more than welcome to view the canopy up here in Chichester.
Johnny
Message 3 of 17
Posted by member Joanna Bryant on Monday 19 July 2021
Would you also know the make and model of the twin gas hob in the SE ? One of the burners is letting out a very strong gas stream - not sure if this can be altered repaired or if we need to replace it.
Message 2 of 17
Posted by member Simon Papendick on Monday 19 July 2021
Hi Joanna,
They are part of Shetland Boats Ltd now and if you google them you can call them about getting a replacement
Message 1 of 17
Hi All
I am looking for a new canopy for our Hardy FP 20 SE. I have seen older posts recommending Suffolk Trimmers as they made the originals but can’t find them online any more so not sure if they are still operating,
Any advice please.
Thank you
Joanna
