Message 20 of 20
Posted by member Richard Stewart on Wednesday 27 January 2021
Message 19 of 20
Another pic.
Message 18 of 20
rear lockers
Message 17 of 20
I have used the EVA teak effect flooring and it works very well, cleans easily.
I use my Hardy for fishing trips and the blood etc wipes of okay.
Message 16 of 20
Posted by member Jim leahy on Thursday 21 January 2021
You are welcome, Michael, glad to be able to help.
Jim
Message 15 of 20
Posted by member Michael on Thursday 21 January 2021
Hi Jim,
Many, many for this, all measurements now very nearly match so I can now retire to the garage for a few hours!
Thanks for your help again,
Michael
Message 14 of 20
Posted by member Jim leahy on Wednesday 20 January 2021
19 inches to kickboard and 17 inches face to face
Message 13 of 20
Posted by member Kenny clark on Monday 18 January 2021
Michael,
No problem happy to help.
Looking at Flexiteek think they also have another brand Isoteek. Using template paper you can send this to company to bond decking, edging to your specification. My preference is DIY option as not a large area.
It is 4-5kg mtr sq. They recommend a heavy roller to help fix decking onto adhesive www.flexiteek.co.uk
EVA - This seems to be a foam type with surface finish. Read article that stated it does not have same surface burn protection.
Carpet - Not for me as this could hold water.
Worth getting samples as price varies ,like everything boat!
Good luck,
Message 12 of 20
Posted by member Michael on Monday 18 January 2021
Hi Jim and Kenny,
Thank you both for the information, another lockdown project can be started. Obviously I will err on the side of safety!
Just a couple of questions,
To Jim:
Can you confirm the measurement just below the two horizontal 11" measurements. Is it 14"? I can't quite see and the pic doesn't enlarge well.
To Kenny:
Flooring will be a future project for me. May I ask a what type you used? I have been looking at the EVA teak striped stuff on Ebay (see link) but don't know if it is robust enough.
https://www.ebay.co.uk/itm/240x90cm-6mm-Brown-Marine-Boat-Yacht-Flooring-Decking-EVA-Foam-Teak-Carpet-Sheet/154086677547?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Message 7 of 20
Posted by member Jim leahy on Sunday 17 January 2021
Michael,
Drawing of layout.
Jim
Message 6 of 20
Michael, boat will be here until next Saturday, if you need anything further. Jim
Message 5 of 20
Posted by member Kenny Clark on Sunday 17 January 2021
Michael,
I was measuring up for synthetic decking. Hope this helps.
Message 4 of 20
Posted by member Jim leahy on Saturday 16 January 2021
Michael,
Will take a few photo’s to make sure when I take measurements
Jim
Message 3 of 20
Posted by member Michael on Saturday 16 January 2021
Hello Jim,
Thanks for your offer of help, hope this works, unable to get to the boat.
The measurement I am after on this drawing is just the distance between 'seat locker' top left and 'galley over berth' roughly top centre.
Not all boats are the same but ours has an empty space in this area. See attached 'hopefully'.
Thanks again,
Michael
Message 2 of 20
Michael
If you text me a photo to explain what you are looking for exactly, I can measure it for you tomorrow. I have an 1984 Family Pilot. I am new to boating so still trying to get my head around the basic terminology.
Jim
+353 87 9180825
Message 1 of 20
Visiting the boat at the moment can hardly be described as essential so I wonder if anyone can help me with a little information so that I can get on with a woodworking project at home.
Do you know, or can you remember, the measurement, on the port side, between the front of the stern port locker and the back of the galley grp moulding?
I want to make a step/stool to fit in this space, sitting on the floor, to make it easier to step down into the cockpit. I suspect that this is a project others have undertaken.
The boat is an '86 Family Pilot, the stern lockers are glassed in ply with carpet over, the galley contains a two burner cooker with folding cover and a circular sink. No modifications, looks pretty 'standard' to me.
Any help much appreciated, I won't blame you if it doesn't subsequently fit!
