Posted by member Simon Kidd on Thursday 5 July 2018
Looks good David, and a great price, well done!
Posted by member Demelza on Thursday 5 July 2018
For those of you have been waiting expectantly for my solution to my Hardy 25 cockpit hatch problem. The solution is here - I have had the original canvas and ply cover copied. Cost £80 and done in under 48hrs by local trimmer.
David
Posted by member Demelza on Tuesday 29 May 2018
I'm trying to do this at the moment. I first mention it in the thread : Skylight in the hinged-cockpit hatch of a Regatta.
I measured up the hatch to find that the front and back edges are bowed. With the centre being 20mm higher than the ends. I have spoken with one plastics provider who tells me that I can't bend an acrylic (anything thicker than 2mm) through this arc. Not really sure what to do. I currently have, what appears to be original, a canvas cover in a barely usable state.
May be I could either grind the bow level (not sure of the consequences of this) or get a frame fabricated that would level the bow.
Any thought anyone.
Dave
Posted by member Simon Kidd on Friday 25 May 2018
Phil.
The Hardy 25 used to have a canvas / PVC cover over the hatch fitting as standard - they weren't fitted with hatches Par Se.
Otherwise if still needed, I can measure up and draw a diagram on one of my hatch covers.
HOC Tech Sec.
Posted by member Mark James on Monday 9 April 2018
Hi Phil,
Just an idea as I doubt you will get an original hatch unless someone has a breaker for spare parts. My Hardy 25 is having repairs and a few upgrades done by Simon Papendick of J-Star Boat Services. He may well be able to copy the original one on my boat for you if you give him a call. He will also come to your mooring if needed. Kind regards. Mark
Posted by member Sky Pilot on Thursday 29 March 2018
Previous owner of our Hardy 25 replaced the cockpit hatch with a standard double glazed window which now leaks. I would like to replace or restore with original patttern hatch. Does anyone know where I could find such a replacement hatch?
Thank you
Phil
