Message board > Navigation & sea worthiness > Transom Well for Inboard Engine to Outboard Conversion
Posted by member Henry on Monday 27 April 2026
Hi Col - thanks for the tip.
The transom well is completed: next are harbour trials, remote steering set-up and then sea trials. Should be interesting.
Henry
Posted by member colin on Wednesday 22 April 2026
Hi Henry, a brave thing you do here and not one I would personally agree with but each to their own!
Try 'Googling' Transom well/splash well modification, there is a wealth of information contained on there for ideas, hopefully you will find what you need there!
Atb
Posted by member Henry on Friday 17 April 2026
And here's a photo ....
Afternoon All
I've cut down the transom, plugged the hole where the outdrive used to be, and and mounted the outboard.
Now just pondering a design for the well. Probably just a box made from marine ply. Henry
Posted by member Henry on Saturday 11 April 2026
Morning All
I've removed the inboard diesel engine from my Navigator, and am in the process of cutting down the transom and fitting a well to accommodate a small outboard engine. This will hang on its bracket over the transom.
Does anyone have experience of designing and installing a simple and rugged transom well ?
(I've heard it called a "splashwell", but at sea one might expect more than a splash.)
Henry
