Message 16 of 16
Posted by member Simon Papendick on Friday 6 November 2026
92mm
Message 15 of 16
Posted by member Martin Smith on Wednesday 23 September 2026
Hi All
Apologies if this has been answered elsewhere, but can anyone tell me the diameter of the rope fender fitted to a Hardy 25?
Mine is currently without and i want to restore it to its original condition.
Martin
Message 14 of 16
Posted by member Simon Papendick on Wednesday 19 August 2026
Hi Ian,
It depends on the boat and if there is an outboard in the way when using a strap to tension the ends of the rope fender.across the outboard well.
Message 13 of 16
Posted by member Ian Petrie on Tuesday 28 July 2026
I'm confident about removing the fender but less so installing, particularly tensioning, the new one. My boat is kept on The Thames near Marlow. Can anyone recommend someone in the area who may be able to do the job?
Message 12 of 16
Posted by member Derek Simpson on Monday 14 July 2025
Thanks Col. I got my synthetic fender from Tradline at Braunstone. It's now fitted and, I think, pretty good.
It was by no means the cheapest but being local to me was the most convenient.
Derek
Message 11 of 16
Posted by member colin on Monday 14 July 2025
Hi Derek, you could try Rope Services UK in the NE
https://www.ropeservicesuk.com/?srsltid=AfmBOookG9Rkm4Jq1kDSK-G4P66kXbis83K_wjROHodGmnOclvit18ft
Message 10 of 16
Posted by member Capricorn on Sunday 13 July 2025
If anyone wants the wire core from my old rope fender they are welcome to it.
It's still in the slightly tatty coir rope which could be used again.
Collection only.
I'm near Colchester in Essex.
Message 9 of 16
Posted by member Derek Simpson on Monday 6 January 2025
I will be replacing the rope fender on my Pilot 20 shortly. I've been in touch with SSC Systems in Norfolk. Unfortunately they do not supply synthetic which I think I'm going for this time. Does anyone know of any alternatives to Rope Services? Thanks.
Derek
Message 8 of 16
Posted by member Peter Clubbe on Thursday 5 December 2024
Hi Ray,
Well if the synthetic is the same price as the coir then that is a very good price, especially as the Pilot is longer than the Navigator. Just had mine back from Rope Services, very pleased with it, done in synthetic hemp, looks identical to traditional rope. Cost £480 in total using my existing wire core. Won't be fitting it 'til Spring now but should be ok as it's the same wire rope. Had to replace some of the hardwood support rail, but most of it is ok. The rot was under the scuppers so a length of shrink wrap should sort that when it goes back on.
Message 7 of 16
Posted by member Capricorn on Monday 25 November 2024
I have just purchased a new Coir rope fender for my Hardy family Pilot from SSCSystems in Norfolk (Tel no 01493 443380) who originally provided Hardy with rope fenders. I found them very helpful.
The cost for a replacement ready to fit rope fender, complete with wire core, scupper drain protectors, Vat and carriage was just under £400.00.
The diameter of the rope is identical to the original, 58-60mm. There is a choice of synthetic and Coir.
Ray.
Message 6 of 16
Posted by member Peter Clubbe on Tuesday 29 October 2024
Thanks for that info and advice Robert, reassuring. I'll place the order for the 60 with Rope Services. Cheers, Peter
Message 5 of 16
Posted by member Robert Sneddon on Friday 25 October 2024
Hi Peter
It was the 60 that I fitted and found it looked fine.
Once you’ve centred the rope on the boat . I supported it along the sides at various points with some twine before starting to secure it.
Message 4 of 16
Posted by member Peter Clubbe on Sunday 20 October 2024
Hi Robert, just came across this post, am about to replace the rope on my Navigator, Rope Services have quoted me £385 + Vat + delivery etc etc which all adds up to £480 approx., using my existing core wire. They're offering a 60mm diameter synthetic replacement, but I note from several other posts that there seems to be some debate as to the correct size, with 72mm being stated as the original. I've measured the distance between the underside of the gunwale and the top of the wood rail and it's approx 65mm. Was the one you fitted 60mm and did it fill the "gap" adequately?
Cheers Peter
Message 3 of 16
Posted by member Robert Sneddon on Thursday 12 October 2023
Hi Tom
Meant to add that I found fitting the rope was quite straight forward. Get someone to help you.
Message 2 of 16
Hi Tom
Yes I've used this company twice. I assume it’s the same company at Houghton-le-Spring.
First rope for my Family Pilot was a natural one which lasted a reasonable time however I replaced it with a synthetic one which I perhaps should have done the first time.
I didn’t need a new wire rope so I just sent it to them to re use. If you need a new rope I believe there are companies around that can supply coated wire with a fitted eyelet which may be cheaper.
My price from memory was a bit less than what you’ve been quoted but it seems to be the way of things nowadays. My rope was a good price at the time in comparison to others.
Found them to be very helpful and always answered the phone if I needed to phone them.
Hope this helps
Message 1 of 16
Posted by member Tom Smith on Wednesday 11 October 2023
Hello all,
I have come across Rope services UK to supply my Hardy motorsailer with a new fender rope,
Has anyone bought through this company and is the price good? Has anyone had experience fitting?
The cost for re-roping is £385.00 plus VAT using your existing wire core.
If a new wire core is needed then the additional cost for this is
£110.00 plus VAT.
Thanks Tom
