Message board > Engines > Fuel Primer Bulb and Fuel Line Arrangement
Posted by member Clive ffitch on Thursday 28 January 2021
Thanks Richard, I'm definitely preferring changing to the setup as yours, with primer bulb between engine and filter. As for filter, thanks Peter, I am now leaning towards keeping the quicksilver standard filter with no glass/plastic bowl below, which seems more in line with the BSS, should Adele ever need to conform to it, and somehow seems less prone to leak or damage?
I get my filter changed usually every season with the service. Does anyone have a feeling for how much if any water is ever collected by the (no glass bowl) filters?
Thanks!
Posted by member Richard Stewart on Wednesday 27 January 2021
Hi Clive,
My primer bulb is fitted between the outboard and the filter.
Most of the time you do not even have to use it for the engine to start instantly, a suzuki DF 70 as the fuel is retained between engine and filter.
I personaly would fit a manual switch between tanks as well to omit any fuel spillage.
On my hardy 20 I have a large 40 litre tank fitted into the port side stern locker to obviate the need to swap over tanks.
Posted by member Peter Cox on Sunday 17 January 2021
The Boat Safety Scheme has a policy on glass filter bowls; Even if you don't have to comply with the BSS, you or a prospective buyer of your boat might be in the future. An extract from their website is:
"Fuel filters can be prone to the heat from a fire and impact damage. Failure of a fuel filter can lead to additional fuel being added to any fire. You must only use appropriate fire resistant and impact resistant fuel filters designed for marine use. Clear bowl, glass or plastic filters meeting these criteria are acceptable, as long as they are designed for use with the fuel-type. Alternatively, fuel filters marked with ISO 10088 are also acceptable. [2.16]"
Posted by member Keith Lathwell on Sunday 17 January 2021
Hi Clive,
if your original fuel system has proved to be reliable I would suggest leaving it as it is. I would then replicate the system for the second tank. This would give you two separate fuel systems. You of course will have the minor inconvenience of changing over supplies at the engine "quick connect"
Rgds Keith
Posted by member Clive ffitch on Friday 15 January 2021
Hi again,
Apart from moving the primer bulb, I also have a "standard" Quicksilver fuel filter/water separator with screw-in element but no see-through bowl and drain valve. Is it worth swapping to a filter/water separator that does have a drain?
Thanks,
Posted by member Clive ffitch on Saturday 9 January 2021
Hi everyone,
I have a conundrum. We have two 30L fuel tanks on Adele with a Mariner 75HP 4-stroke engine, and the fuel line setup has always been "fueltank-primerbulb-fuelfilter-engine" with the need to manually disconnect and reconnect fuel tanks when swapping tanks (see "Present Set-up" in the diagram). This sequence is as it was when we bought Adele, and is indeed as recommended by a good number of sources.
Having already decided to install a manual fuel tank switchover valve to avoid the annoying and somewhat less safe swapping of fuel connections when one tank gets low or empty, I have decided to also review the position of the fuel primer bulb. Having not really questioned it before, it does take a while to prime the engine if left a while between runs, and the primer bulb never really seems to get suitably hard as you would expect, despite swapping for a new one. I can only assume partly due to the presence of the large filter unit upstream, possible air in it, the overall length of the fuel line, and very possibly the orientation of the primer bulb being horizontal. I am therefore of a mind to move the primer bulb closer to the engine, and ideally vertical, such that the setup will then be "fueltank-fuelfilter-primerbulb-engine" (see "Proposed Set-up" in the diagram, complete with switchover valve installed). This sequence is also as recommended by a good number of other sources!
I am thinking that having the primer bulb closet to the engine is the more sensible, thus making the whole priming operation far more immediate and robust, and also because the primer bulb would pull fuel through the filter, rather than trying to push fuel through it.
What does everyone else think?
Thank you in advance for your much appreciated deliberations!
