Posted by member David Freeman on Monday 6 May 2019
Took the boat out for a test run, hydrofoil does make notable difference, bow down quite a few degrees and onto the plane easier and at lower speed (around 17 knots) so all in all I am pleased with this inexpensive result. I admit trim tabs would be more noticeable and efficient but perhaps look to have them fitted next year.
Posted by member David Freeman on Tuesday 30 April 2019
Hydrofoil fitted, will share results when I have tested it to the max !
Posted by member Rob on Tuesday 23 April 2019
Hello David
I have a Navigator fitted with hydrofoil / doel fins. These were fitted when I purchased it. Yes it will get up on the plane but it may have done do so without them. I get the impression it would get up on the plain at a lower speed if fitted with adjustable trim tabs. I have a 50hp Mariner 4-stroke Bigfoot engine.
There is a lot of debate about them on the other forums which may help you make up your mind. If you do decide to give it a try, there are lots of them on eBay for sale at £18.00. You will need to drill 2 holes each side on the cavitation plate.
The Bosun is a heavier and bigger boat but you do have a bigger engine than me.
Sorry I cannot be of more help.
Posted by member Robert snedd9n on Tuesday 23 April 2019
Hi David
The only experience I have with hydrofoils was my previous boat which was 17ft.
I thought there was a slight improvement but in my opinion not a lot.
My current Family Pilot is heavier so decided on Bennett hydraulic trim tabs. Best decision I made.
Yes more expensive but certainly worth it.
Good luck with whatever choice you decide to go with.
Posted by member David Freeman on Friday 5 April 2019
I have a Hardy Bosun with Suzuki DF 70, considering fitting a hydrofoil to give a bit more stability and bow down at speed. Rather than go to the expense of trim tabs (budget a bit tight) thought this may help. Any thoughts or experience on this?
Main use of boat is Chichester harbour , Solent to IOW.
Would appreciate any feed back.
