Message 9 of 9
Posted by member Keith on Monday 24 September 2018
Thanks very helpful.
Keith
Message 8 of 9
Posted by member Simon Papendick on Monday 24 September 2018
Hi Keith,
Your boat would have been built between 1987 and 1992.
Message 7 of 9
Thanks. Will do.
keith
Message 6 of 9
Posted by member Hardy Editor on Monday 24 September 2018
Hi Keith,
If the little metal plate which Rob has mentioned has been removed by someone, then have a look on the top surface of the hull where it curves around at the stern and you should see the boat number etched into the grp. Get back to me with the number if you can find it and I will try and find a build date for you.
HOC Editor
Message 5 of 9
Thanks for the helpful update and confirmation of the model. Do you know roughly when these were built and was the hull design the same as the standard Pilot.
Keith
Message 4 of 9
Posted by member Simon Papendick on Sunday 23 September 2018
Hi Keith,
It is indeed a river pilot and one that was build during my time at Hardy Marine.
Former Hardy Marine employee
Message 3 of 9
Posted by member Rob on Sunday 23 September 2018
Hello Keith
Welcome to the forum.
If it has folding doors and no bulkhead, it is likely to be a River Pilot.
If you get the number off the metal builders plate (which is normally below the steering wheel) and phone Hardy Marine, they will probably give you the year of manufacture and also confirm it is a River Pilot.
Message 2 of 9
Posted by member Keith on Saturday 22 September 2018
Having explored web sites. I am hoping this is the Hardy River Pilot - mid '80s.
Message 1 of 9
I have recently purchased what wwas described as a Hardy 20ft Pilot. Although I have seen it I have not yet taken possession. It is securely locked in a marina and collection will be in two weeks. I cannot identify the model as a Pilot. There is no porthole and the deck in front of the wheelhouse seems to be shorter tham most. The wheelhouse has folding doors and there are two bunks. I am wondering whether it is actually a Navigator and wonder whether anybody can assist?
